[Bio] / FigKernelScripts / fix_ext_funcs.pl Repository:
Log of /FigKernelScripts/fix_ext_funcs.pl
Thu Jun 16 18:27:08 2005 UTC (14 years, 5 months ago) by overbeek
Diff to selected 1.2
routines to support derivation of sprout data
