[Bio] / FigKernelScripts / find_neighbors_using_figfams.pl Repository:
Annotation of /FigKernelScripts/find_neighbors_using_figfams.pl
Revision 1.8 - (view) (download) (as text)
1 : gdpusch 1.1 # -*- perl -*-
2 :     ########################################################################
3 :     # Copyright (c) 2003-2006 University of Chicago and Fellowship
4 :     # for Interpretations of Genomes. All Rights Reserved.
5 :     #
6 :     # This file is part of the SEED Toolkit.
7 :     #
8 :     # The SEED Toolkit is free software. You can redistribute
9 :     # it and/or modify it under the terms of the SEED Toolkit
10 :     # Public License.
11 :     #
12 :     # You should have received a copy of the SEED Toolkit Public License
13 :     # along with this program; if not write to the University of Chicago
14 :     # at info@ci.uchicago.edu or the Fellowship for Interpretation of
15 :     # Genomes at veronika@thefig.info or download a copy from
16 :     # http://www.theseed.org/LICENSE.TXT.
17 :     ########################################################################
18 :
19 :     use strict;
20 :     use warnings;
21 :
22 :     use FIG;
23 :     my $fig = new FIG;
24 :
25 :     use FigFams;
26 :     use ToCall;
27 :     use NewGenome;
28 :
29 :     $0 =~ m/([^\/]+)$/o;
30 :     my $self = $1;
31 :     my $usage = "usage: $self [-fams=FigfamsData] To_Call_Dir N FoundFamilies [old] > closest.N.genomes";
32 :
33 :     if (@ARGV && ($ARGV[0] =~ m/-h(elp)?/)) {
34 :     print STDERR "\n $usage\n\n";
35 :     exit (0);
36 :     }
37 :
38 :     my ($i, $fam_data, $to_call_dir, $N, $foundF);
39 :
40 : gdpusch 1.8 #...First, let's determine which FigfamsData directory to use:
41 : gdpusch 1.1 for ($i=0; ($i < @ARGV) && ($ARGV[$i] !~ /^-fams=/); $i++) {}
42 :     if ($i < @ARGV) {
43 :     if ($ARGV[$i] =~ /^-fams=(\S+)/) {
44 :     if (-d $1) {
45 :     $fam_data = $1;
46 :     }
47 :     else {
48 :     die "Nonexistent FIGfams directory $1\n";
49 :     }
50 :     splice(@ARGV,$i,1);
51 :     }
52 :     }
53 :
54 : olson 1.6 my $figfams = new FigFams($fig, $fam_data);
55 :
56 : gdpusch 1.1 # Now pick up the normal parameters
57 :     (
58 :     ($to_call_dir = shift @ARGV) &&
59 :     ($N = shift @ARGV) &&
60 : gdpusch 1.7 ($foundF = shift @ARGV)
61 : gdpusch 1.1 )
62 :     || die "\n $usage\n\n";
63 :
64 :
65 :     ### This is a bit complex. Normally, one uses this program to call genes
66 :     # in a newly-sequenced genome. In this case the functionality of NewGenome.pm
67 :     # is needed. To call genes in an existing genome (to, for example, see how well
68 :     # we are doing) you would use ToCall.pm.
69 :
70 :     my $to_call;
71 : overbeek 1.3 my $old;
72 :
73 : gdpusch 1.1 if ((@ARGV > 0) && ($ARGV[0] =~ /^old/i)) {
74 : overbeek 1.3 $old = 1;
75 : gdpusch 1.1 $to_call = new ToCall($to_call_dir);
76 :     }
77 :     else {
78 :     $to_call = new NewGenome($to_call_dir);
79 :     }
80 :
81 : gdpusch 1.8
82 :     open(FOUNDFAMS, ">>$foundF") || die "Could not append-open $foundF";
83 :
84 :     my $called_by_file = "$to_call_dir/called_by";
85 :     open(CALLED_BY, ">>$called_by_file")
86 :     || die "Could not append-open $called_by_file";
87 :
88 :
89 :     #+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
90 :     #...Get the current ORF-calls if they exist;
91 :     # else, try to call a set of candidate ORFs.
92 :     #-----------------------------------------------------------------------
93 : gdpusch 1.1 my @orf_ids = $to_call->get_fids_for_type('orf');
94 :     if (not @orf_ids) {
95 : gdpusch 1.8 $to_call->possible_orfs();
96 : gdpusch 1.1 @orf_ids = $to_call->get_fids_for_type('orf');
97 :     }
98 :
99 :     my (%seq_of, %len_of, $orf_len);
100 :     for my $fid (@orf_ids) {
101 : gdpusch 1.2 if (($orf_len = $to_call->get_feature_length($fid)) > 900) {
102 : gdpusch 1.1 $len_of{$fid} = $orf_len;
103 :     $seq_of{$fid} = $to_call->get_feature_sequence($fid);
104 :     }
105 :     }
106 :
107 : gdpusch 1.7
108 : gdpusch 1.1 my @peg_ids = ();
109 :     my %genomes_hit;
110 :     my %weight_of_hits;
111 :     foreach my $orf_id (sort { $len_of{$b} <=> $len_of{$a} } keys %len_of) {
112 : gdpusch 1.2
113 :     print STDERR "\nChecking $orf_id ($len_of{$orf_id})\n" if $ENV{VERBOSE};
114 : gdpusch 1.1 my ($fam, $sims) = $figfams->place_in_family($seq_of{$orf_id});
115 : gdpusch 1.2 if (not defined($fam)) {
116 :     print STDERR "\tCould not place in family --- skipping\n" if $ENV{VERBOSE};
117 :     next;
118 :     }
119 :     else {
120 : gdpusch 1.1 my $fam_id = $fam->family_id();
121 :     my $func = $fam->family_function();
122 : gdpusch 1.2 print STDERR "\tplaced in $fam_id ("
123 :     , (scalar @$sims)
124 :     , " sims)\t$func\n"
125 :     if $ENV{VERBOSE};
126 : gdpusch 1.1
127 : overbeek 1.3 my $fid;
128 :     if (! $old)
129 :     {
130 : gdpusch 1.7 my $annot = [ qq(RAST),
131 :     qq($func\nCalled by "$self" using FIGfam $fam_id.)
132 :     ];
133 :     my $orf = &NewGenome::ORF::new('NewGenome::ORF', $to_call, $orf_id);
134 :     $fid = $orf->promote_to_peg($sims, $func, $annot);
135 : gdpusch 1.8
136 :     if ($fid) {
137 :     print CALLED_BY "$fid\t$self\n";
138 :     print FOUNDFAMS "$fid\t$fam_id\t$func\n";
139 :     }
140 :     else {
141 :     die "Could not promote $orf_id";
142 :     }
143 : overbeek 1.3 }
144 : gdpusch 1.8
145 : gdpusch 1.2 if ($fid) {
146 :     push @peg_ids, $fid;
147 :
148 :     for ($i=0; ($i < $N) && ($i < @$sims); ++$i) {
149 :     ++$genomes_hit{&FIG::genome_of($sims->[$i]->id2)};
150 : gdpusch 1.8 next unless $sims->[$i]->ln2;
151 : gdpusch 1.2 $weight_of_hits{&FIG::genome_of($sims->[$i]->id2)} +=
152 : gdpusch 1.4 ($sims->[$i]->bsc / $sims->[$i]->ln2);
153 : gdpusch 1.2 }
154 :     }
155 :     else {
156 :     die "Could not promote $orf_id";
157 : gdpusch 1.1 }
158 :     }
159 : gdpusch 1.2
160 : gdpusch 1.1 last if (@peg_ids >= $N);
161 :     }
162 :
163 :     my $num_pegs = @peg_ids;
164 :     warn "Found $num_pegs PEG candidates\n";
165 :
166 :     if ($num_pegs == 0) {
167 :     die "Could not find any features of sufficient length and in a FIGfam\n";
168 :     }
169 :
170 :     my @best = sort { $weight_of_hits{$b} <=> $weight_of_hits{$a} } keys(%genomes_hit);
171 :     for ($i=0; ($i < $N) && ($i < @best); ++$i) {
172 :     print "$best[$i]\t$genomes_hit{$best[$i]}\t$weight_of_hits{$best[$i]}\n";
173 :     }
174 : gdpusch 1.7
175 :     $to_call->export_features();
176 :
177 :     close(CALLED_BY);
178 : gdpusch 1.1 close(FOUNDFAMS);
179 :
180 :     exit(0);
