[Bio] / FigKernelScripts / find_neighbors_using_figfams.pl Repository:
Log of /FigKernelScripts/find_neighbors_using_figfams.pl
Wed Feb 13 23:04:18 2008 UTC (11 years, 11 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Changes since 1.7: +24 -16 lines
Diff to previous 1.7 , to selected 1.5
Added comments, divide-by-zero protection, and removed an ill-thought-out hand-optimization that was writing duplicate FIDs to the "called_by" file. -- /gdp
Wed Feb 13 14:54:27 2008 UTC (11 years, 11 months ago) by gdpusch
Changes since 1.6: +17 -4 lines
Final clean-up. -- /gdp
Thu Jan 31 15:31:39 2008 UTC (12 years ago) by olson
Changes since 1.5: +3 -5 lines
Put reporting of family directory used in the FigFams constructor, only printed if REPORT_FIGFAM_DETAILS
is specified in the environment.
Make the FIG_Config defaulting work properly for the figfams directory.
Wed Jan 30 22:50:37 2008 UTC (12 years ago) by olson
Log the pathname to the figfams directory used for the analysis.
Fri Dec 7 22:19:15 2007 UTC (12 years, 1 month ago) by gdpusch
Reconciled the normalization used by both "find_neighbors" scripts. -- /gdp
Fri Sep 14 18:10:21 2007 UTC (12 years, 4 months ago) by overbeek
Changes since 1.2: +14 -2 lines
fixes to ToCal.pm
Fri Jun 1 04:19:16 2007 UTC (12 years, 8 months ago) by gdpusch
Changes since 1.1: +29 -11 lines
Fixed various bugs in initial version. -- /gdp
Fri Jun 1 02:14:30 2007 UTC (12 years, 8 months ago) by gdpusch
Diff to selected 1.5
Find neighbors using long non-universal proteins. -- /gdp
