[Bio] / FigKernelScripts / find_neighbors_using_figfams.pl Repository:
View of /FigKernelScripts/find_neighbors_using_figfams.pl
Revision 1.4 - (download) (as text) (annotate)
Fri Dec 7 22:19:15 2007 UTC (12 years ago) by gdpusch
Reconciled the normalization used by both "find_neighbors" scripts. -- /gdp
# -*- perl -*-
# Public License.
use strict;
use warnings;
use FIG;
my $fig = new FIG;
use FigFams;
my $figfams = new FigFams($fig);
use ToCall;
use NewGenome;
$0 =~ m/([^\/]+)$/o;
my $self  = $1;
my $usage = "usage: $self [-fams=FigfamsData] To_Call_Dir N FoundFamilies [old] > closest.N.genomes";
if (@ARGV && ($ARGV[0] =~ m/-h(elp)?/)) {
    print STDERR "\n   $usage\n\n";
    exit (0);
my ($i, $fam_data, $to_call_dir, $N, $foundF);
# First, let's determine which FigfamsData directory to use
$fam_data = "$FIG_Config::data/FigfamsData";
for ($i=0; ($i < @ARGV) && ($ARGV[$i] !~ /^-fams=/); $i++) {}
if ($i < @ARGV) {
    if ($ARGV[$i] =~ /^-fams=(\S+)/) {
	if (-d $1) {
	    $fam_data = $1;
	else {
	    die "Nonexistent FIGfams directory $1\n";
	splice(@ARGV,$i,1);
# Now pick up the normal parameters
 ($to_call_dir = shift @ARGV) &&
 ($N           = shift @ARGV) &&
 ($foundF      = shift @ARGV) && open(FOUNDFAMS, ">>$foundF")
    || die "\n   $usage\n\n";
### This is a bit complex.  Normally, one uses this program to call genes
# in a newly-sequenced genome.  In this case the functionality of NewGenome.pm
# is needed.  To call genes in an existing genome (to, for example, see how well
# we are doing) you would use ToCall.pm.
my $to_call;
my $old;
if ((@ARGV > 0) && ($ARGV[0] =~ /^old/i)) {
    $old = 1;
    $to_call = new ToCall($to_call_dir);
else {
    $to_call = new NewGenome($to_call_dir);
my @orf_ids = $to_call->get_fids_for_type('orf');
if (not @orf_ids) {
    $to_call->possible_orfs;
my (%seq_of, %len_of, $orf_len);
for my $fid (@orf_ids) {
    if (($orf_len = $to_call->get_feature_length($fid)) > 900) {
	$len_of{$fid} = $orf_len;
	$seq_of{$fid} = $to_call->get_feature_sequence($fid);
my @peg_ids = ();
my %genomes_hit;
my %weight_of_hits;
foreach my $orf_id (sort { $len_of{$b} <=> $len_of{$a} } keys %len_of) {
    print STDERR "\nChecking $orf_id ($len_of{$orf_id})\n" if $ENV{VERBOSE};
    my ($fam, $sims) = $figfams->place_in_family($seq_of{$orf_id});
    if (not defined($fam)) {
	print STDERR "\tCould not place in family --- skipping\n" if $ENV{VERBOSE};
	next;
    else {
	my $fam_id = $fam->family_id();
	my $func   = $fam->family_function();
	print STDERR "\tplaced in $fam_id ("
	    , (scalar @$sims)
	    , " sims)\t$func\n"
	    if $ENV{VERBOSE};
	my $fid;
	if (! $old)
	    my $orf = &NewGenome::ORF::new('NewGenome::ORF', $to_call, $orf_id);
	    $fid = $orf->promote_to_peg($sims, $func);
	else
	    $fid = $orf_id;
	if ($fid) {
	    push @peg_ids, $fid;
	    print FOUNDFAMS "$fid\t$fam_id\t$func\n";
	    for ($i=0; ($i < $N) && ($i < @$sims); ++$i) {
		++$genomes_hit{&FIG::genome_of($sims->[$i]->id2)};
		$weight_of_hits{&FIG::genome_of($sims->[$i]->id2)} +=
		    ($sims->[$i]->bsc / $sims->[$i]->ln2);
	else {
	    die "Could not promote $orf_id";
    last if (@peg_ids >= $N);
my $num_pegs = @peg_ids;
warn "Found $num_pegs PEG candidates\n";
if ($num_pegs == 0) {
    die "Could not find any features of sufficient length and in a FIGfam\n";
my @best = sort { $weight_of_hits{$b} <=> $weight_of_hits{$a} } keys(%genomes_hit);
for ($i=0; ($i < $N) && ($i < @best); ++$i) {
    print "$best[$i]\t$genomes_hit{$best[$i]}\t$weight_of_hits{$best[$i]}\n";
close(FOUNDFAMS);
$to_call->export_features;
exit(0);
