[Bio] / FigKernelScripts / find_missing_genes.pl Repository:
Log of /FigKernelScripts/find_missing_genes.pl
Wed Aug 4 03:08:27 2010 UTC (9 years, 4 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +8 -5 lines
more RAST fixes (some of these may need to be backported to use the SAP version
outside rast, but the immediate need is for the rast version)
Tue Aug 3 20:42:53 2010 UTC (9 years, 4 months ago) by olson
Changes since 1.8: +18 -4 lines
Use FIGV to get nonreference genome info in rast.
Fri Jul 16 14:58:13 2010 UTC (9 years, 4 months ago) by gdpusch
Changes since 1.7: +3 -2 lines
Changed file check to whether correspondence table exists, not has nonzero size; correct typo that was returning $func instead of $len.
Mon Apr 12 00:15:47 2010 UTC (9 years, 8 months ago) by gdpusch
CVS Tags: rast_rel_2010_0526
Changes since 1.6: +4 -3 lines
Added check to only accept BBHs from corresponding genes table.
Thu Apr 1 23:02:15 2010 UTC (9 years, 8 months ago) by gdpusch
Changes since 1.5: +53 -11 lines
Fixed serious bug in gap computation.
Thu Mar 4 17:14:57 2010 UTC (9 years, 9 months ago) by gdpusch
Minor cosmetic changes.
Tue Mar 2 21:35:58 2010 UTC (9 years, 9 months ago) by gdpusch
Changes since 1.3: +7 -4 lines
Minor changes to ouput and error formats.
Tue Mar 2 20:21:59 2010 UTC (9 years, 9 months ago) by gdpusch
Changes since 1.2: +33 -55 lines
Changed output to key/value format; removed HTML output and most output to STDERR unless $ENV{VERBOSE}=1
Tue Mar 2 18:08:47 2010 UTC (9 years, 9 months ago) by gdpusch
Minor fixes.
Tue Mar 2 13:27:06 2010 UTC (9 years, 9 months ago) by gdpusch
Initial checkin.
