[Bio] / FigKernelScripts / find_genes_in_families.pl Repository:
Log of /FigKernelScripts/find_genes_in_families.pl
Thu Nov 5 19:45:28 2009 UTC (10 years ago) by olson
Changes since 1.21: +4 -3 lines
Diff to previous 1.21
Switch to FFs and FF instead of FigFams and FigFam
Tue Jul 7 22:29:05 2009 UTC (10 years, 4 months ago) by gdpusch
Changes since 1.20: +2 -2 lines
Diff to previous 1.20
Major rewrite to prevent already-found PEGs from being re-called by every stage of RAST.
Wed Feb 13 14:54:27 2008 UTC (11 years, 9 months ago) by gdpusch
Changes since 1.19: +43 -17 lines
Diff to previous 1.19
Final clean-up. -- /gdp
Thu Jan 31 15:31:39 2008 UTC (11 years, 9 months ago) by olson
Changes since 1.18: +1 -3 lines
Diff to previous 1.18
Put reporting of family directory used in the FigFams constructor, only printed if REPORT_FIGFAM_DETAILS
is specified in the environment.
Make the FIG_Config defaulting work properly for the figfams directory.
Wed Jan 30 22:50:37 2008 UTC (11 years, 9 months ago) by olson
Changes since 1.17: +2 -0 lines
Diff to previous 1.17
Log the pathname to the figfams directory used for the analysis.
Thu May 17 12:38:28 2007 UTC (12 years, 6 months ago) by gdpusch
Changes since 1.16: +17 -23 lines
Diff to previous 1.16
Minor cosmetic changes. -- /gdp
Fri Apr 27 19:14:35 2007 UTC (12 years, 6 months ago) by overbeek
Changes since 1.15: +13 -3 lines
fixes to rapid propagation
Sat Oct 14 21:47:20 2006 UTC (13 years, 1 month ago) by overbeek
package up the steps in rapid propoagation
Sat Oct 14 20:48:51 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.13: +0 -6 lines
do not promote genes that fail to match a FIGfam
Sat Oct 14 04:35:38 2006 UTC (13 years, 1 month ago) by overbeek
Minor cosmetic change to debugging output. -- /gdp
Thu Oct 12 17:58:08 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.11: +5 -1 lines
Added optional debugging info. -- /gdp
Thu Oct 12 10:35:22 2006 UTC (13 years, 1 month ago) by overbeek
Added check to make sure $sims is defined before re-calling STARTs. -- /gdp
Thu Oct 12 07:45:24 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.9: +6 -2 lines
Fixed failure to re-call STARTs and duplicate declarations. -- /gdp
Thu Oct 5 00:28:58 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.8: +15 -21 lines
fixes to rapid prop technology and added diffsF.cgi
Wed Oct 4 18:59:47 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.7: +16 -1 lines
Added copyleft notice. -- /gdp
Mon Sep 18 21:19:56 2006 UTC (13 years, 2 months ago) by overbeek
Script defaults to SEED copy of FigfamsData. -- /gdp
Mon Sep 18 21:12:21 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.5: +34 -8 lines
spiff up the lock/unlock stuff
Sat Sep 2 12:37:00 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.4: +8 -3 lines
fix minor error in find_genes_based_on_neighbors
Thu Jun 29 14:59:53 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.3: +4 -9 lines
fixes to find_genes_in_families
Tue May 30 02:50:58 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.2: +32 -10 lines
fixs to rapid propagation
Wed Apr 12 13:10:38 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.1: +22 -34 lines
fixes to making assignments based on consistency
Sat Apr 1 18:26:58 2006 UTC (13 years, 7 months ago) by overbeek
add initial terrible version of find_genes_in_families.pl
