[Bio] / FigKernelScripts / find_gaps.pl Repository:
Log of /FigKernelScripts/find_gaps.pl
Fri May 15 23:52:36 2009 UTC (10 years, 10 months ago) by gdpusch
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.8: +3 -3 lines
Fixed (hopefully) incorrectly handled out-of-bounds cases.
Thu Dec 20 07:53:36 2007 UTC (12 years, 3 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Changes since 1.7: +6 -1 lines
Fixed error in lower boundary constraint. -- /gdp
Tue Oct 23 18:13:57 2007 UTC (12 years, 5 months ago) by gdpusch
Changes since 1.6: +22 -9 lines
Added 5-prime guard-zone extension option. -- /gdp
Wed Oct 17 08:53:20 2007 UTC (12 years, 5 months ago) by gdpusch
Changes since 1.5: +65 -26 lines
Added 5prime padding. -- /gdp
Wed Jul 11 14:51:34 2007 UTC (12 years, 9 months ago) by gdpusch
Changes since 1.4: +3 -4 lines
Fixed missing STDERR in VERBOSE-mode line. -- /gdp
Thu Sep 14 17:36:43 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.3: +22 -9 lines
Improved error-handling. -- /gdp
Mon Aug 7 10:49:16 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.2: +4 -3 lines
Minor cosmetic changes. -- /gdp
Thu Jun 8 17:43:12 2006 UTC (13 years, 10 months ago) by overbeek
Fixed error in 'usage' msg. -- /gdp
Thu Jun 1 22:18:21 2006 UTC (13 years, 10 months ago) by overbeek
Initial checkin. -- /gdp
