[Bio] / FigKernelScripts / find_gaps.pl Repository:
Log of /FigKernelScripts/find_gaps.pl
Links to mgrast_rel_2008_1110: (view) (download) (as text) (annotate)
Thu Dec 20 07:53:36 2007 UTC (12 years, 5 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Changes since 1.7: +6 -1 lines
Diff to previous 1.7 , to selected 1.5
Fixed error in lower boundary constraint. -- /gdp
Tue Oct 23 18:13:57 2007 UTC (12 years, 7 months ago) by gdpusch
Changes since 1.6: +22 -9 lines
Added 5-prime guard-zone extension option. -- /gdp
Wed Oct 17 08:53:20 2007 UTC (12 years, 7 months ago) by gdpusch
Changes since 1.5: +65 -26 lines
Added 5prime padding. -- /gdp
Wed Jul 11 14:51:34 2007 UTC (12 years, 10 months ago) by gdpusch
Changes since 1.4: +3 -4 lines
Fixed missing STDERR in VERBOSE-mode line. -- /gdp
Thu Sep 14 17:36:43 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.3: +22 -9 lines
Improved error-handling. -- /gdp
Mon Aug 7 10:49:16 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.2: +4 -3 lines
Minor cosmetic changes. -- /gdp
Thu Jun 8 17:43:12 2006 UTC (14 years ago) by overbeek
Fixed error in 'usage' msg. -- /gdp
Thu Jun 1 22:18:21 2006 UTC (14 years ago) by overbeek
Diff to selected 1.5
Initial checkin. -- /gdp
