[Bio] / FigKernelScripts / find_SEED_SSU_rRNA_genes.pl Repository:
Log of /FigKernelScripts/find_SEED_SSU_rRNA_genes.pl
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Mon May 4 20:54:03 2009 UTC (10 years, 11 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.3: +4 -2 lines
Add type field to output report (always rna).
Mon May 4 18:19:57 2009 UTC (10 years, 11 months ago) by golsen
Changes since 1.2: +78 -5 lines
Add command options
Sat Feb 21 15:37:22 2009 UTC (11 years, 1 month ago) by overbeek
CVS Tags: rast_rel_2009_03_26
minor fixes
Sat Feb 21 15:20:35 2009 UTC (11 years, 1 month ago) by overbeek
Gary Olsen's SSU finding script
