[Bio] / FigKernelScripts / find_SEED_SSU_rRNA_genes.pl Repository:
Log of /FigKernelScripts/find_SEED_SSU_rRNA_genes.pl
Thu Sep 19 19:09:49 2013 UTC (6 years, 8 months ago) by golsen
Changes since 1.6: +6 -5 lines
Update the reference RNA module name.
Mon Aug 27 21:41:48 2012 UTC (7 years, 9 months ago) by fangfang
Changes since 1.5: +3 -3 lines
fixed a bug in reference sequences package name
Wed Aug 15 16:45:14 2012 UTC (7 years, 9 months ago) by golsen
Changes since 1.4: +41 -19 lines
Improved calling of genes (I think).
Mon May 4 20:54:03 2009 UTC (11 years, 1 month ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.3: +4 -2 lines
Add type field to output report (always rna).
Mon May 4 18:19:57 2009 UTC (11 years, 1 month ago) by golsen
Changes since 1.2: +78 -5 lines
Add command options
Sat Feb 21 15:37:22 2009 UTC (11 years, 3 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26
minor fixes
Sat Feb 21 15:20:35 2009 UTC (11 years, 3 months ago) by overbeek
Gary Olsen's SSU finding script
