[Bio] / FigKernelScripts / find_RNA_genes.pl Repository:
Log of /FigKernelScripts/find_RNA_genes.pl
Sat Mar 21 21:47:32 2015 UTC (4 years, 7 months ago) by golsen
CVS Tags: HEAD
Make blast+ the default in find_nucleotide_homologs, solving an issue
with occasional errors in blastall output.
Add a new wrapper (find_RNA_genes) based on svr_RNA_genes, that does
not include SEED and/or Sappling genome support.
Do not copy the DNA file supplied by the user.
Add command line support for fraction sequence coverage.
Improve documentation.
