[Bio] / FigKernelScripts / figfam_quality_control.pl Repository:
Log of /FigKernelScripts/figfam_quality_control.pl
Thu Oct 8 18:52:15 2009 UTC (10 years, 1 month ago) by arodri7
Changes since 1.7: +25 -6 lines
commit changes
Wed Jun 18 15:18:51 2008 UTC (11 years, 4 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.6: +1 -0 lines
update changes
Thu Apr 17 20:48:15 2008 UTC (11 years, 6 months ago) by olson
Introduct &FIG::get_figfams_data()
Sun Apr 13 04:25:17 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.4: +5 -0 lines
add organisms to FIGfam quality control
Fri Apr 11 12:00:34 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.3: +1 -3 lines
updates to FIGfam quality control
Thu Apr 10 00:52:46 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.2: +5 -6 lines
simplified versions
Mon Apr 7 21:38:31 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.1: +30 -52 lines
fixes to quality control for FigFams
Mon Mar 31 18:17:19 2008 UTC (11 years, 7 months ago) by arodri7
added the figfam quality control processes to the overall update process
