[Bio] / FigKernelScripts / figfam.pl Repository:
Log of /FigKernelScripts/figfam.pl
Thu Nov 11 17:43:21 2010 UTC (9 years, 3 months ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.22: +6 -6 lines
Diff to previous 1.22
FigFam 6 digit problem
Thu May 1 02:40:50 2008 UTC (11 years, 10 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_release_2008_09_29
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
add connections between FIGfams and structures
Thu Apr 17 20:48:15 2008 UTC (11 years, 10 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Diff to previous 1.20
Introduct &FIG::get_figfams_data()
Fri Apr 11 14:15:16 2008 UTC (11 years, 10 months ago) by overbeek
Changes since 1.19: +7 -5 lines
Diff to previous 1.19
changes to FIGfams
Sat Mar 1 15:52:45 2008 UTC (12 years ago) by overbeek
Diff to previous 1.18
changes from ::data/FigfamsData to ::FigfamsData
Wed Oct 24 14:25:28 2007 UTC (12 years, 4 months ago) by overbeek
Changes since 1.17: +9 -0 lines
Diff to previous 1.17
add families_imlementing_role to FigFams.pm
Sat Oct 6 14:45:01 2007 UTC (12 years, 4 months ago) by overbeek
Changes since 1.16: +13 -0 lines
Diff to previous 1.16
updates to computation of VCs
Thu Oct 4 00:58:56 2007 UTC (12 years, 4 months ago) by overbeek
Changes since 1.15: +34 -0 lines
check figfams fixes
Sun Mar 18 01:19:06 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.14: +1 -0 lines
add help for alignment command in figfam.pl
Sat Feb 24 03:03:04 2007 UTC (13 years ago) by overbeek
try again with the minor fix
Sat Feb 24 03:00:25 2007 UTC (13 years ago) by overbeek
Changes since 1.12: +2 -2 lines
very minor fix to figfam.pl
Wed Feb 21 16:09:36 2007 UTC (13 years ago) by overbeek
Changes since 1.11: +23 -0 lines
Fixes to FigFam.pm
Sun Feb 18 16:08:18 2007 UTC (13 years ago) by overbeek
fix error message in figfam.pl
Sun Dec 31 13:00:10 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.9: +11 -0 lines
minor fix to check_all_subsystems
Mon Dec 25 17:14:15 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.8: +5 -0 lines
changes to support updating FIGfam functions
Wed Jun 21 20:49:21 2006 UTC (13 years, 8 months ago) by overbeek
fixes to by_annotator.cgi
Sun May 7 04:03:10 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.6: +13 -3 lines
add new_versions_of_features
Wed May 3 13:18:22 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.5: +36 -5 lines
 update genome parameters in default assignments
Mon Apr 3 19:28:52 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.4: +5 -0 lines
updates to ARPP/STAG
Sat Apr 1 18:24:23 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.3: +51 -12 lines
fixes and errors to STAG
Sat Mar 25 23:12:56 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.2: +40 -17 lines
add very buggy start of NewGenome.pm and FigFam stuff
Tue Mar 21 15:53:30 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.1: +0 -24 lines
fixes to split_and_trim
Wed Mar 1 20:10:56 2006 UTC (14 years ago) by overbeek
add FigFam stuff
