[Bio] / FigKernelScripts / fig_xmlrpc_server.pl Repository:
Log of /FigKernelScripts/fig_xmlrpc_server.pl
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Mon Jun 21 22:08:14 2004 UTC (15 years, 7 months ago) by mkubal
Changes since 1.3: +25 -0 lines
script to get ECs with no genes
Thu Jun 10 13:46:28 2004 UTC (15 years, 7 months ago) by olson
Uncomment the exit ...
Mon May 24 15:55:52 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.1: +86 -15 lines
Add distinction between utility and method calls.
Tue May 4 16:35:22 2004 UTC (15 years, 8 months ago) by olson
Diff to selected 1.3
XMLRPC server for the FIG.pm routines.
Meant to be invoked as the backend to the FIG.py python interface.
