[Bio] / FigKernelScripts / fig.pl Repository:
Log of /FigKernelScripts/fig.pl
Revision 1.133 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 23 23:39:22 2008 UTC (11 years, 7 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.132: +10 -43 lines
Diff to previous 1.132
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name.  assign_function
treats everyone as master (but writes an annotation with the real user
name).
Revision 1.132 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jun 28 05:58:33 2008 UTC (11 years, 9 months ago) by overbeek
CVS Tags: rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.131: +134 -3 lines
Diff to previous 1.131
code relating to dlit/ilit maintenance
Revision 1.131 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 11 14:15:16 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.130: +1 -1 lines
Diff to previous 1.130
changes to FIGfams
Revision 1.130 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 5 17:29:23 2008 UTC (12 years, 1 month ago) by olson
Changes since 1.129: +9 -0 lines
Diff to previous 1.129
add get_corresponding_ids
Revision 1.129 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Nov 19 20:34:57 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.128: +7 -7 lines
Diff to previous 1.128
Changes to make the passing of a sims cutoff of 0 work properly (using defined($maxP) instead  of $maxP
as a test to see if maxP was set).
Revision 1.128 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 23 14:44:36 2007 UTC (12 years, 5 months ago) by overbeek
Changes since 1.127: +1 -1 lines
Diff to previous 1.127
minor typo in fig.pl
Revision 1.127 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 13 15:10:06 2007 UTC (12 years, 5 months ago) by overbeek
Changes since 1.126: +2 -1 lines
Diff to previous 1.126
fixes to fc_figfams
Revision 1.126 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 24 20:53:51 2007 UTC (12 years, 6 months ago) by overbeek
Changes since 1.125: +14 -0 lines
Diff to previous 1.125
add a routine in FIG.pm giving who set the function of a peg
Revision 1.125 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 28 14:02:05 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.124: +15 -0 lines
Diff to previous 1.124
fixes to rebuilding figfams
Revision 1.124 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 26 16:43:12 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.123: +29 -1 lines
Diff to previous 1.123
minor fixes to supporting deletion of features
Revision 1.123 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 25 19:43:17 2007 UTC (12 years, 9 months ago) by gdpusch
Changes since 1.122: +7 -5 lines
Diff to previous 1.122
Added "v" (viral) filter to "genomes" coommand. -- /gdp
Revision 1.122 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 15 18:52:08 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.121: +24 -0 lines
Diff to previous 1.121
set up fig command to handle adding features from a file
Revision 1.121 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Apr 28 14:47:53 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.120: +1 -0 lines
Diff to previous 1.120
add best_tree_using_proml_on_cluster
Revision 1.120 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 27 16:53:44 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.119: +7 -0 lines
Diff to previous 1.119
add recast_ids
Revision 1.119 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 8 18:34:32 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.118: +10 -4 lines
Diff to previous 1.118
Added &get_dna_seq($fid). -- /gdp
Revision 1.118 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 18 03:08:57 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.117: +5 -0 lines
Diff to previous 1.117
add comments to functions
Revision 1.117 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 13 23:36:00 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.116: +12 -14 lines
Diff to previous 1.116
fixes to add_feature, delete_feature, and replace_feature_with
Revision 1.116 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 1 23:22:45 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.115: +6 -0 lines
Diff to previous 1.115
add GO attribute genertation
Revision 1.115 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 30 23:04:16 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.114: +16 -0 lines
Diff to previous 1.114
put in the fr2go stuff
Revision 1.114 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 29 20:59:44 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.113: +8 -0 lines
Diff to previous 1.113
Add FIGV support for peg/subsystem indexing.
Revision 1.113 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 29 15:19:19 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.112: +10 -0 lines
Diff to previous 1.112
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Revision 1.112 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 15 18:36:53 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.111: +22 -0 lines
Diff to previous 1.111
introduce locks on features to block assignments
Revision 1.111 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 14 22:22:29 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.110: +1 -1 lines
Diff to previous 1.110
Fixed obsolete form of boundaries_of.
Revision 1.110 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 13 23:32:15 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.109: +5 -0 lines
Diff to previous 1.109
RAE: moving PIRSF to links
Revision 1.109 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 19 13:48:16 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.108: +1 -1 lines
Diff to previous 1.108
bugfix.
Revision 1.108 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 19 13:44:05 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.107: +10 -2 lines
Diff to previous 1.107
Some changes to add_genome logic.
(Only log after genome add completes; turn some formerly fatal errors into nonfatal
with warnings so that we don't end up with a partially-added genome).
Revision 1.107 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 18 12:27:21 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.106: +8 -0 lines
Diff to previous 1.106
add normalizded bit scores to BBHs
Revision 1.106 - (view) (download) (as text) (annotate) - [select for diffs]
Sun May 7 12:25:12 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.105: +4 -3 lines
Diff to previous 1.105
minor changes to logging correspondences
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Sun May 7 04:04:40 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.104: +8 -0 lines
Diff to previous 1.104
add ability to log arbitrary correspondences
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 5 14:38:00 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.103: +91 -32 lines
Diff to previous 1.103
added new logging
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 4 20:05:54 2006 UTC (13 years, 11 months ago) by olson
Changes since 1.102: +20 -10 lines
Diff to previous 1.102
Turn off sim server support unless enabled in FIG_Config,for now.
add dont_mark_complete to fig add_genome.
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 28 18:09:19 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.101: +24 -0 lines
Diff to previous 1.101
must have a role index on subsystem_index, added is_NMPDR_genome, etc.
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Feb 14 15:07:08 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.100: +20 -1 lines
Diff to previous 1.100
add logging on update operations
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Feb 5 01:08:16 2006 UTC (14 years, 2 months ago) by overbeek
Changes since 1.99: +16 -0 lines
Diff to previous 1.99
RAE: Swtiched to using SQL Count for the number of contigs
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 25 04:12:20 2006 UTC (14 years, 2 months ago) by overbeek
Changes since 1.98: +1 -1 lines
Diff to previous 1.98
RAE: Updating proteinfamilies
Revision 1.98 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 23 19:20:54 2006 UTC (14 years, 2 months ago) by overbeek
Changes since 1.97: +28 -0 lines
Diff to previous 1.97
changes to support dynamic sims and updates
Fri Jan 13 20:22:40 2006 UTC (14 years, 2 months ago) by overbeek
Changes since 1.96: +25 -0 lines
Diff to previous 1.96
fixes to deleted_features, replace_features_with, etc
Thu Jan 5 01:17:24 2006 UTC (14 years, 3 months ago) by overbeek
Changes since 1.95: +10 -3 lines
Diff to previous 1.95
RAE: Adding subsystem_genomes and correct genomes_for_subsystems
Tue Jan 3 18:31:43 2006 UTC (14 years, 3 months ago) by efrank
Changes since 1.94: +7 -0 lines
Diff to previous 1.94
add subsystems_having_organism
Sat Dec 24 21:03:57 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.93: +0 -1 lines
Diff to previous 1.93
serious problem in setting max_expand in FIG::sims
Wed Dec 21 23:51:50 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.92: +18 -0 lines
Diff to previous 1.92
RAE: Adding statistics to protein families
Tue Dec 20 17:59:09 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.91: +7 -0 lines
Diff to previous 1.91
add abstract functional coupling
Changes since 1.90: +17 -0 lines
Diff to previous 1.90
Thu Dec 1 22:28:13 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.89: +2 -1 lines
Diff to previous 1.89
Making attributes work for Ed
Wed Nov 23 20:34:59 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.88: +16 -1 lines
Diff to previous 1.88
major changes to attributes and protein families. There are changes to several modules to deal with new attributes database, and simultaneous updates to protein families
Tue Oct 11 20:40:57 2005 UTC (14 years, 5 months ago) by efrank
CVS Tags: caBIG-00-00-00
Changes since 1.87: +12 -0 lines
Diff to previous 1.87
add find_by_attribute. this takes a single string arg and returns triples,
(featureId, key, value) of all attributes in which the search tstring
is a substring of either key or value. the search is via the attribute
table, not via the glimpse indesces so that searches immediately after edits
of attribs still work.
not sure i've got th parse of the args right (for strings that are multiple words)
Tue Oct 11 00:25:33 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.86: +2 -2 lines
Diff to previous 1.86
adding maximum expansion to sims
Mon Oct 10 20:09:56 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.85: +4 -3 lines
Diff to previous 1.85
add_attributes bug fix
Thu Oct 6 22:44:02 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.84: +3 -3 lines
Diff to previous 1.84
adding more functions with external ids
Thu Oct 6 21:22:48 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.83: +14 -0 lines
Diff to previous 1.83
loading external ids and external protein families
Tue Oct 4 02:29:29 2005 UTC (14 years, 6 months ago) by redwards
CVS Tags: caBIG-dataload-0
Changes since 1.82: +8 -0 lines
Diff to previous 1.82
adding differentiate protein families
Mon Oct 3 20:02:53 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.81: +7 -0 lines
Diff to previous 1.81
adding command line method to add a single attribute
Fri Sep 30 16:00:19 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.80: +8 -0 lines
Diff to previous 1.80
Add "init_local_sim_computation" method to create a sim computation askfor pool.
Sun Sep 4 15:13:20 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.79: +5 -0 lines
Diff to previous 1.79
add ability to get epoch date from fig.pl
Fri Sep 2 22:21:57 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.78: +6 -19 lines
Diff to previous 1.78
Add $fig->add_annotations_batch() that does filehandle conservation and uses COPY TABLE instead
of INSERT to add annotations to the database. Now used by 'fig add_annotations' so that
large annotation file installs don't take overnight.
Fri Sep 2 16:27:14 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.77: +10 -3 lines
Diff to previous 1.77
Allow the user  to specify a time to convert with epoch_to_readable
Fri Aug 19 19:52:19 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.76: +13 -0 lines
Diff to previous 1.76
Adding more details to organisms.cgi and correcting get_key_values
Wed Aug 17 02:52:18 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.75: +7 -0 lines
Diff to previous 1.75
adding erase attribute
Tue Aug 16 19:41:59 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.74: +28 -0 lines
Diff to previous 1.74
NMPDR updates.
Mon Aug 8 21:08:56 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.73: +7 -14 lines
Diff to previous 1.73
minor mod to make ss by homol better on memory
Mon Aug 8 19:42:47 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.72: +26 -0 lines
Diff to previous 1.72
find protein families for proteins in a genome
Sat Aug 6 00:32:22 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.71: +5 -1 lines
Diff to previous 1.71
adding help to the commmand line
Fri Aug 5 16:22:53 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.70: +13 -3 lines
Diff to previous 1.70
subsystems by homology really by homology
Fri Aug 5 16:07:26 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.69: +1 -1 lines
Diff to previous 1.69
correcting spelling
Fri Aug 5 16:03:33 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.68: +16 -0 lines
Diff to previous 1.68
find pegs in subsys by homoology
Fri Aug 5 13:14:26 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.67: +28 -11 lines
Diff to previous 1.67
adding options to add_genome
Wed Aug 3 23:00:37 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.66: +3 -2 lines
Diff to previous 1.66
Adding a force to the add_genomes
Mon Aug 1 18:52:58 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.65: +22 -1 lines
Diff to previous 1.65
update stuff relating to protein families
Fri Jul 29 18:14:21 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.64: +2 -2 lines
Diff to previous 1.64
Support "fig load_all N" and "fig load_all list"
Fri Jul 22 16:17:06 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.63: +14 -0 lines
Diff to previous 1.63
adding get_keys to fig.pl
Tue Jul 12 00:34:32 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.62: +7 -7 lines
Diff to previous 1.62
updates to build protein families
Mon Jun 20 17:04:45 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2
Changes since 1.61: +19 -3 lines
Diff to previous 1.61
add new protein family routines
Mon Jun 13 16:43:57 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: Root-bobdev_news
Changes since 1.60: +14 -1 lines
Diff to previous 1.60
Ross change commit after cleanup
Thu Jun 9 05:51:06 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.59: +1 -1 lines
Diff to previous 1.59
Wed Jun 1 01:18:50 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.58: +15 -0 lines
Diff to previous 1.58
Thu May 12 20:38:37 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.57: +11 -0 lines
Diff to previous 1.57
add tool to generate gene blocks for variation analysis
Thu Apr 21 14:08:50 2005 UTC (14 years, 11 months ago) by overbeek
Diff to previous 1.56
Fixed typo in default pscore for sims command. -- /gdp
Wed Apr 13 00:03:52 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.55: +9 -0 lines
Diff to previous 1.55
fixed load_attributes. Hopefully
Thu Apr 7 19:16:10 2005 UTC (15 years ago) by redwards
Changes since 1.54: +1 -5 lines
Diff to previous 1.54
many changes to key/value pairs to make them work
Thu Apr 7 02:18:04 2005 UTC (15 years ago) by golsen
Changes since 1.53: +1 -1 lines
Diff to previous 1.53
Fix to search_index so that it can take multiple word query.
Sat Apr 2 11:56:12 2005 UTC (15 years ago) by overbeek
Changes since 1.52: +6 -0 lines
Diff to previous 1.52
add update_subsys_conflicts to fig.pl
Wed Feb 9 20:15:42 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.51: +5 -0 lines
Diff to previous 1.51
put UniProt ids in trees of columns
Mon Jan 24 19:18:38 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.50: +12 -0 lines
Diff to previous 1.50
correct concept of user assign in make_annotations_for_sprout
Sun Dec 5 14:01:53 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.49: +1 -1 lines
Diff to previous 1.49
fix to help for seqs_with_role
Wed Nov 3 17:46:17 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.48: +6 -0 lines
Diff to previous 1.48
add is_complete function to FIG.pm
Tue Nov 2 14:45:31 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.47: +15 -0 lines
Diff to previous 1.47
fix bug in subsys.cgi and add Literature to Global
Sun Oct 17 00:02:34 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.46: +1 -1 lines
Diff to previous 1.46
fixes to UniProt IDs on chromosomal_clusters.cgi
Fri Oct 15 17:04:09 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.45: +16 -11 lines
Diff to previous 1.45
peg links generalized to fid links
Fri Oct 1 19:48:37 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.44: +0 -1 lines
Diff to previous 1.44
minor fixes to exporting sets
Wed Sep 22 17:25:38 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.43: +2 -2 lines
Diff to previous 1.43
restructured code for presenting chromosomal clusters
Mon Sep 13 02:12:21 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.42: +14 -0 lines
Diff to previous 1.42
add attributes as key-value pairs attached to fids
Wed Aug 18 18:46:19 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.41: +33 -0 lines
Diff to previous 1.41
commit untested implementation of feature maintenance
Wed Jun 2 17:18:55 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.40: +2 -2 lines
Diff to previous 1.40
alter length constraint on BBHs
Tue Jun 1 19:07:45 2004 UTC (15 years, 10 months ago) by mkubal
Changes since 1.39: +16 -4 lines
Diff to previous 1.39
correct fig.pl to be able to use FIGrpc
Wed May 19 14:15:57 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.38: +11 -0 lines
Diff to previous 1.38
add all_contigs
Wed May 19 13:17:39 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.37: +19 -1 lines
Diff to previous 1.37
fixes on memory leak and genome version
Tue Apr 27 21:31:30 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.36: +11 -4 lines
Diff to previous 1.36
add the old pull_orfs
Tue Apr 27 15:41:28 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.35: +11 -0 lines
Diff to previous 1.35
basic query tools
Sat Apr 24 15:02:08 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.34: +13 -0 lines
Diff to previous 1.34
tools for McCune to build expert automated assignments
Fri Apr 23 21:49:03 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.33: +2 -2 lines
Diff to previous 1.33
fixes to index.cgi to blast against all complete
Fri Apr 23 16:59:41 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.32: +15 -0 lines
Diff to previous 1.32
fixes to best_bbh_candidates
Thu Apr 1 14:54:57 2004 UTC (16 years ago) by overbeek
Changes since 1.31: +13 -0 lines
Diff to previous 1.31
fixes to candidates for a role
Mon Mar 29 23:11:55 2004 UTC (16 years ago) by mkubal
Changes since 1.30: +146 -150 lines
Diff to previous 1.30
added routines to fig.pl
Thu Mar 25 18:40:21 2004 UTC (16 years ago) by mkubal
Changes since 1.29: +55 -254 lines
Diff to previous 1.29
functions added to help menu by MK 03/25/04
Tue Mar 23 20:42:11 2004 UTC (16 years ago) by mkubal
Changes since 1.28: +517 -20 lines
Diff to previous 1.28
fig.pl updated with marked subroutines from FIG.pm by Mike Kubal 3/23/04
Tue Mar 23 01:04:35 2004 UTC (16 years ago) by overbeek
Diff to previous 1.27
fix exporting chromosomal clusters
Fri Mar 19 18:45:37 2004 UTC (16 years ago) by overbeek
Changes since 1.26: +2 -0 lines
Diff to previous 1.26
fixes to coupling and protein.cgi
Thu Mar 18 21:38:57 2004 UTC (16 years ago) by gdpusch
Changes since 1.25: +8 -2 lines
Diff to previous 1.25
Added "verify_dir()" function. -- /mike
Wed Mar 17 20:18:22 2004 UTC (16 years ago) by overbeek
Changes since 1.24: +36 -8 lines
Diff to previous 1.24
for Gordon and Mike
Wed Mar 17 18:17:34 2004 UTC (16 years ago) by overbeek
Changes since 1.23: +18 -0 lines
Diff to previous 1.23
basic export of subsystems stuff
Tue Mar 9 03:55:40 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.22: +9 -1 lines
Diff to previous 1.22
add load_distances
Wed Mar 3 14:56:43 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.21: +22 -0 lines
Diff to previous 1.21
add merged annotations
Wed Mar 3 12:49:23 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.20: +13 -0 lines
Diff to previous 1.20
fixes from DOE meeting
Thu Feb 5 14:05:53 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.19: +4 -3 lines
Diff to previous 1.19
handle complete genomes in fig
Thu Feb 5 03:29:26 2004 UTC (16 years, 2 months ago) by overbeek
Diff to previous 1.18
allow complete option on genomes
Fri Jan 16 14:59:48 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.17: +12 -4 lines
Diff to previous 1.17
add ability to process assignment sets
Fri Jan 9 19:05:45 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.16: +9 -3 lines
Diff to previous 1.16
stuff
Fri Jan 9 04:28:42 2004 UTC (16 years, 3 months ago) by overbeek
fix auto_assign
Thu Jan 8 20:43:47 2004 UTC (16 years, 3 months ago) by overbeek
fix spelling
Tue Jan 6 23:08:26 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.13: +4 -4 lines
fix in extract_genomes
Tue Jan 6 18:14:48 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.12: +21 -0 lines
fix stick behavior for checked sims
Tue Jan 6 13:19:18 2004 UTC (16 years, 3 months ago) by overbeek
make args consistent for auto assignment
Tue Jan 6 11:52:31 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.10: +24 -44 lines
translate auto_assignments
Mon Dec 29 02:22:37 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.9: +6 -0 lines
numerous performance issues
Sun Dec 28 17:11:29 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.8: +6 -0 lines
cleanup issues relating to large numbers of partial genomes
Sat Dec 20 21:08:43 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.7: +20 -1 lines
fixed issues relating to addition/deletion of genomes
Sat Dec 20 15:19:21 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.6: +5 -0 lines
for incremental additions to the DB, delete old versions of things
Fri Dec 19 20:09:34 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.5: +0 -6 lines
get rid of set_urls, since it will not work anymore
Fri Dec 5 15:33:56 2003 UTC (16 years, 4 months ago) by overbeek
CVS Tags: delong-01, delong-02
fix auto_assignG in fig
Thu Dec 4 21:35:45 2003 UTC (16 years, 4 months ago) by overbeek
Changes since 1.3: +9 -1 lines
add trans to function_of
Wed Dec 3 21:24:31 2003 UTC (16 years, 4 months ago) by overbeek
Changes since 1.2: +38 -2 lines
Wed Dec 3 19:39:29 2003 UTC (16 years, 4 months ago) by efrank
Changes since 1.1: +32 -0 lines
fixed a bunch of changes
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-00, V00-00-01
Makefile:
All the rest:
