[Bio] / FigKernelScripts / fid2dna.pl Repository:
Log of /FigKernelScripts/fid2dna.pl
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Mon May 10 02:35:34 2004 UTC (15 years, 6 months ago) by overbeek
add pegs and fid2dna
