[Bio] / FigKernelScripts / features_with_role.pl Repository:
Log of /FigKernelScripts/features_with_role.pl
Mon Oct 1 17:32:07 2007 UTC (12 years, 6 months ago) by golsen
Function to get the ids or sequences of features that match a given role.
Uses FIG::seqs_with_role.
