[Bio] / FigKernelScripts / fast_blastp.pl Repository:
Log of /FigKernelScripts/fast_blastp.pl
Mon Feb 11 16:55:48 2008 UTC (12 years, 1 month ago) by overbeek
fast_blastp is a tool to support rapid similarity estimates using FIGfam partitions
