[Bio] / FigKernelScripts / extract_sp_links.pl Repository:
Log of /FigKernelScripts/extract_sp_links.pl
Wed Nov 15 20:25:47 2006 UTC (13 years, 4 months ago) by olson
fix -h error
Wed Sep 28 21:59:43 2005 UTC (14 years, 6 months ago) by overbeek
Extract PubMed links from SwissProt/TrEMBL/UniProt .dat files. -- /gdp
