[Bio] / FigKernelScripts / extract_DNA_sequence_from_object_for_start_predictions.pl Repository:
Log of /FigKernelScripts/extract_DNA_sequence_from_object_for_start_predictions.pl
Mon Dec 5 18:56:37 2005 UTC (14 years, 6 months ago) by olson
Mon Jan 17 01:27:44 2005 UTC (15 years, 4 months ago) by overbeek
Diff to selected 1.2
add start prediction code
