[Bio] / FigKernelScripts / extract_DNA_sequence_from_object_for_start_predictions.pl Repository:
Log of /FigKernelScripts/extract_DNA_sequence_from_object_for_start_predictions.pl
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Mon Jan 17 01:27:44 2005 UTC (15 years, 5 months ago) by overbeek
add start prediction code
