[Bio] / FigKernelScripts / extend_subsys.pl Repository:
Log of /FigKernelScripts/extend_subsys.pl
Mon Sep 4 20:21:31 2006 UTC (13 years, 5 months ago) by redwards
using is_environmental instead of seven 9s
Fri Feb 25 22:51:37 2005 UTC (15 years ago) by overbeek
fix error on passing user to index.cgi -- header fix
Thu Feb 24 12:10:12 2005 UTC (15 years ago) by overbeek
Changes since 1.3: +10 -1 lines
extend variants of 0
Sat Feb 12 04:01:01 2005 UTC (15 years ago) by overbeek
Changes since 1.2: +3 -1 lines
many fixes to extending subsystems
Fri Feb 11 03:42:05 2005 UTC (15 years ago) by overbeek
Changes since 1.1: +11 -12 lines
add new extend_subsys
Mon Jan 31 14:01:07 2005 UTC (15 years ago) by overbeek
add pegs_in_subsystems
