[Bio] / FigKernelScripts / export_subsystem_as_gff.pl Repository:
Log of /FigKernelScripts/export_subsystem_as_gff.pl
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Wed Apr 27 23:44:41 2005 UTC (14 years, 6 months ago) by olson
script to write a subsystem as a set of gff files + a spreadsheet.
