[Bio] / FigKernelScripts / export_similarity_request.pl Repository:
Log of /FigKernelScripts/export_similarity_request.pl
Wed Feb 15 22:12:27 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.2: +41 -4 lines
minor fixes to assignment for close strains
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Wed May 25 16:07:40 2005 UTC (14 years, 5 months ago) by olson
Script to invoke sim request export.
