[Bio] / FigKernelScripts / exp_pc_compute.pl Repository:
Log of /FigKernelScripts/exp_pc_compute.pl
Tue Aug 9 18:49:15 2011 UTC (8 years, 8 months ago) by parrello
CVS Tags: mgrast_dev_10262011, rast_rel_2011_0928
Changed to make it easier to debug.
Fri Jul 22 19:12:45 2011 UTC (8 years, 8 months ago) by parrello
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.6: +59 -46 lines
Added passive mode.
Wed Jul 20 13:32:14 2011 UTC (8 years, 8 months ago) by parrello
more bugs
Wed Jul 20 13:20:49 2011 UTC (8 years, 8 months ago) by parrello
This time for sure.
Wed Jul 20 13:15:39 2011 UTC (8 years, 8 months ago) by parrello
Bug fixes... Hard to debug this way...
Wed Jul 20 13:09:35 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.2: +55 -53 lines
Fixed directory recursion.
Tue Jul 19 19:59:05 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.1: +21 -2 lines
Fixed some bugs.
Tue Jul 19 19:35:51 2011 UTC (8 years, 8 months ago) by parrello
Diff to selected 1.4
New script
