[Bio] / FigKernelScripts / evaluate_quality_of_trees.pl Repository:
Log of /FigKernelScripts/evaluate_quality_of_trees.pl
Mon Jan 29 18:59:08 2007 UTC (13 years, 2 months ago) by overbeek
debugged version of bring_tree_up_to_ali
Thu Jan 11 19:59:54 2007 UTC (13 years, 2 months ago) by overbeek
delete temp directories in phylogeny tools
Mon Jan 8 19:47:28 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.1: +34 -6 lines
add tree_neighbors and latest phylogeny stuff
Thu Dec 21 21:11:28 2006 UTC (13 years, 3 months ago) by overbeek
fixes to writing newick trees and a program to evaluate trees
