[Bio] / FigKernelScripts / ev_code_cron.pl Repository:
Log of /FigKernelScripts/ev_code_cron.pl
Tue Jun 10 16:27:22 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.7: +10 -0 lines
add creation and making attributes from dlits and ilits
Thu Nov 16 22:56:01 2006 UTC (13 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Fixed the problem with the "1"s being put into the URL field.
Fri Aug 25 13:59:18 2006 UTC (13 years, 7 months ago) by redwards
hopefully final change to make ev_code_crons smooooth
Thu Aug 24 22:28:16 2006 UTC (13 years, 7 months ago) by redwards
killing error messages
Thu Aug 24 21:48:55 2006 UTC (13 years, 7 months ago) by redwards
trying hard to fix ev_code_cron
Wed Aug 23 20:53:50 2006 UTC (13 years, 7 months ago) by redwards
restoring the ev_code_cron to almost right
Wed Aug 23 18:13:02 2006 UTC (13 years, 7 months ago) by redwards
undoing yesterdays great escapade into attributes ... for now
Sat May 6 22:26:58 2006 UTC (13 years, 11 months ago) by overbeek
RAE: Initial release of evidence code script for cron
