[Bio] / FigKernelScripts / ev_code_cron.pl Repository:
Log of /FigKernelScripts/ev_code_cron.pl
Wed Sep 3 20:34:35 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.15: +2 -1 lines
Updated comments to mention the replacement scripts.
Revision 1.15 - (view) (download) (as text) (annotate) - [selected]
Wed Jul 2 05:54:21 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.14: +1 -8 lines
Modified to use the new evidence code loader.
Sat Jun 28 15:27:49 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.13: +2 -0 lines
Diff to previous 1.13 , to selected 1.15
make ev_code_cron export dlits, add data, and reload them
Sat Jun 28 13:54:36 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.12: +2 -1 lines
Diff to previous 1.12 , to selected 1.15
make compute_extra_dlit_data take Katlyn attributes
Sat Jun 28 06:39:10 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.11: +5 -5 lines
Diff to previous 1.11 , to selected 1.15
switching to new ilidt/dlit stuff
Sat Jun 21 22:02:51 2008 UTC (11 years, 9 months ago) by overbeek
Diff to previous 1.10 , to selected 1.15
remove duplicate dlit/ilit attrs
Wed Jun 18 15:47:56 2008 UTC (11 years, 9 months ago) by overbeek
Diff to previous 1.9 , to selected 1.15
lossen constraints on ilit propagation
Wed Jun 11 16:28:11 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.8: +1 -8 lines
Diff to previous 1.8 , to selected 1.15
Changed to use AttrDBRefresh to load.
Tue Jun 10 16:27:22 2008 UTC (11 years, 10 months ago) by overbeek
Changes since 1.7: +10 -0 lines
Diff to previous 1.7 , to selected 1.15
add creation and making attributes from dlits and ilits
Thu Nov 16 22:56:01 2006 UTC (13 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Diff to previous 1.6 , to selected 1.15
Fixed the problem with the "1"s being put into the URL field.
Fri Aug 25 13:59:18 2006 UTC (13 years, 7 months ago) by redwards
Diff to previous 1.5 , to selected 1.15
hopefully final change to make ev_code_crons smooooth
Thu Aug 24 22:28:16 2006 UTC (13 years, 7 months ago) by redwards
Diff to previous 1.4 , to selected 1.15
killing error messages
Thu Aug 24 21:48:55 2006 UTC (13 years, 7 months ago) by redwards
Diff to previous 1.3 , to selected 1.15
trying hard to fix ev_code_cron
Wed Aug 23 20:53:50 2006 UTC (13 years, 7 months ago) by redwards
Diff to previous 1.2 , to selected 1.15
restoring the ev_code_cron to almost right
Wed Aug 23 18:13:02 2006 UTC (13 years, 7 months ago) by redwards
Diff to previous 1.1 , to selected 1.15
undoing yesterdays great escapade into attributes ... for now
Sat May 6 22:26:58 2006 UTC (13 years, 11 months ago) by overbeek
Diff to selected 1.15
RAE: Initial release of evidence code script for cron
