[Bio] / FigKernelScripts / dump_machine_state.pl Repository:
Log of /FigKernelScripts/dump_machine_state.pl
Sun Jul 31 03:40:05 2005 UTC (14 years, 8 months ago) by olson
Wider ps.
Sun Jul 31 03:39:10 2005 UTC (14 years, 8 months ago) by olson
Debg script to get machine state in case of hangs.
