[Bio] / FigKernelScripts / crc64.py Repository:
Log of /FigKernelScripts/crc64.py
Links to mgrast_dev_12152011: (view) (download) (as text) (annotate)
Fri May 2 17:21:12 2008 UTC (11 years, 7 months ago) by mkubal
uses for mapping of interpro downlaod to pegs
