[Bio] / FigKernelScripts / count_bases.pl Repository:
View of /FigKernelScripts/count_bases.pl
Revision 1.2 - (download) (as text) (annotate)
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
# Public License.
# Usage: count_bases < something.fasta or
#        cat something.fasta | count_bases
$dictP = base_dict_init();
$/ = "\n>";
while (defined($_ = <STDIN>))
    chomp;
    if ($_ =~ /^>?(\S+)[^\n]*\n(.*)/s)
	$sid  =  $1;
	$seq =  $2;
	$seq =~ s/\n//gs;
	$seq =~ s/ //gs;
	$seq =~ s/[\-\.\~]//gs;
	$seq = lc $seq;
	$seq =~ s/u/t/g;
	if ($seq && $sid)
	    print "$sid\t", chars_in_string(\$seq,$dictP), "\n";
sub chars_in_string {
# Counts the number certain characters in a string. Only
# the characters included in the incoming dictionary are
# counted. So this can work for amino acids, bases or ..
# In: Pointer to string
#     Pointer to dictionary hash
# Out: Integer
    local ($stringP,$dictP) = @_;
    my $i = 0;
    foreach $ch (keys %$dictP) {
	$i += $$stringP =~ s/$ch/$ch/g;
    return $i;
sub base_dict_init {
# Returns a dictionary that says whether a character is a
# valid base symbol.
# In:  Nothing
# Out: Pointer to hash
    local %dict;
    $dict{"A"} = $dict{"a"} = 1;
    $dict{"G"} = $dict{"g"} = 1;
    $dict{"C"} = $dict{"c"} = 1;
    $dict{"U"} = $dict{"u"} = 1;
    $dict{"T"} = $dict{"t"} = 1;
    $dict{"R"} = $dict{"r"} = 1;
    $dict{"Y"} = $dict{"y"} = 1;
    $dict{"W"} = $dict{"w"} = 1;
    $dict{"S"} = $dict{"s"} = 1;
    $dict{"M"} = $dict{"m"} = 1;
    $dict{"K"} = $dict{"k"} = 1;
    $dict{"H"} = $dict{"h"} = 1;
    $dict{"D"} = $dict{"d"} = 1;
    $dict{"V"} = $dict{"v"} = 1;
    $dict{"B"} = $dict{"b"} = 1;
    $dict{"N"} = $dict{"n"} = 1;
    return \%dict;
sub complement {
# Returns the complement of a sequence with preservation of case
# complemented ambiguity codes.
    local ($seq) = @_;
    my (%dict); undef %dict;
    my ($cseq) = "";
    $dict{"A"} = "U"; $dict{"a"} = "u";
    $dict{"G"} = "C"; $dict{"g"} = "c";
    $dict{"C"} = "G"; $dict{"c"} = "g";
    $dict{"U"} = "A"; $dict{"u"} = "a";
    $dict{"T"} = "A"; $dict{"t"} = "a";
    $dict{"R"} = "Y"; $dict{"r"} = "y";
    $dict{"Y"} = "R"; $dict{"y"} = "r";
    $dict{"W"} = "W"; $dict{"w"} = "w";
    $dict{"S"} = "S"; $dict{"s"} = "s";
    $dict{"M"} = "K"; $dict{"m"} = "k";
    $dict{"K"} = "M"; $dict{"k"} = "m";
    $dict{"H"} = "D"; $dict{"h"} = "d";
    $dict{"D"} = "H"; $dict{"d"} = "h";
    $dict{"V"} = "B"; $dict{"v"} = "b";
    $dict{"B"} = "V"; $dict{"b"} = "v";
    $dict{"N"} = "N"; $dict{"n"} = "n";
    foreach (reverse split(//,$seq)) {
        $cseq .= $dict{$_};
    return $cseq;
