[Bio] / FigKernelScripts / correct_gff_missing_contigs.pl Repository:
Log of /FigKernelScripts/correct_gff_missing_contigs.pl
Thu Dec 6 20:44:09 2007 UTC (12 years, 4 months ago) by redwards
correcting a weird error
Tue Jul 17 20:26:59 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.3: +10 -3 lines
Make the fact that copy didn't need to be done a nonfatal condition.
Wed Apr 11 17:47:15 2007 UTC (12 years, 11 months ago) by olson
Changes since 1.2: +42 -3 lines
rollup of metagenome server changes
Tue Feb 6 01:31:21 2007 UTC (13 years, 2 months ago) by redwards
Changes since 1.1: +5 -1 lines
removing dependency on prior load
Mon Feb 5 21:57:41 2007 UTC (13 years, 2 months ago) by redwards
Adding a script to replace the contigs file when data is missed (usu. in metagenomes)
