[Bio] / FigKernelScripts / conditionally_assign.pl Repository:
Log of /FigKernelScripts/conditionally_assign.pl
Links to merge-trunktag-bobdev_news-1: (view) (download) (as text) (annotate)
Sat Jan 8 18:22:01 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.1: +10 -6 lines
add check to assign_function
Fri Aug 6 16:13:00 2004 UTC (15 years, 4 months ago) by overbeek
add conditionally_assign
