[Bio] / FigKernelScripts / conditionally_assign.pl Repository:
Log of /FigKernelScripts/conditionally_assign.pl
Sun Dec 4 18:19:04 2011 UTC (8 years, 1 month ago) by golsen
CVS Tags: HEAD, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +12 -7 lines
Just a little more testing and nicer useage info.
Mon Sep 22 12:42:31 2008 UTC (11 years, 4 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_rel_2008_0625, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_release_2008_09_29
Changes since 1.4: +7 -18 lines
get rid of warning and update conditionally_assign
Sat Aug 23 23:39:22 2008 UTC (11 years, 5 months ago) by golsen
CVS Tags: mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919
Changes since 1.3: +6 -24 lines
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name.  assign_function
treats everyone as master (but writes an annotation with the real user
name).
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Sat Jan 8 18:22:01 2005 UTC (15 years ago) by overbeek
Changes since 1.1: +10 -6 lines
add check to assign_function
Fri Aug 6 16:13:00 2004 UTC (15 years, 5 months ago) by overbeek
Diff to selected 1.4
add conditionally_assign
