Log of /FigKernelScripts/conditionally_assign.pl
Parent Directory
Revision
1.5 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Sep 22 12:42:31 2008 UTC (11 years, 2 months ago) by
overbeek
Branch:
MAIN
CVS Tags:
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_rel_2008_0625,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
myrast_33,
myrast_rel40,
rast_2008_0924,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_release_2008_09_29
Changes since
1.4: +7 -18 lines
Diff to
previous 1.4
to
selected 1.6
get rid of warning and update conditionally_assign
Revision
1.4 -
view)
download)
as text)
annotate)
[select for diffs]
Sat Aug 23 23:39:22 2008 UTC (11 years, 3 months ago) by
golsen
Branch:
MAIN
CVS Tags:
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919
Changes since
1.3: +6 -24 lines
Diff to
previous 1.3
to
selected 1.6
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name. assign_function
treats everyone as master (but writes an annotation with the real user
name).
Revision
1.2 -
view)
download)
as text)
annotate)
[select for diffs]
Sat Jan 8 18:22:01 2005 UTC (14 years, 11 months ago) by
overbeek
Branch:
MAIN
CVS Tags:
Root-bobdev_news,
caBIG-00-00-00,
caBIG-dataload-0,
efrank-preMakefileToStandardMk,
merge-bobdev_news-1,
merge-bobdev_news-2,
merge-bodev_news-3,
merge-trunktag-bobdev_news-1,
merge-trunktag-bobdev_news-2,
merge-trunktag-bodev_news-3
Branch point for:
Branch-bobdev_news
Changes since
1.1: +10 -6 lines
Diff to
previous 1.1
to
selected 1.6
add check to assign_function
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
