[Bio] / FigKernelScripts / compute_simple_scores.pl Repository:
Log of /FigKernelScripts/compute_simple_scores.pl
Tue May 31 14:05:18 2005 UTC (14 years, 10 months ago) by overbeek
fixes to computing coupling scores
Tue May 31 12:51:09 2005 UTC (14 years, 10 months ago) by overbeek
fixes to filtering PCHs
Sat May 7 20:57:47 2005 UTC (14 years, 10 months ago) by overbeek
add routines for BigFC
