[Bio] / FigKernelScripts / compute_simple_scores.pl Repository:
Log of /FigKernelScripts/compute_simple_scores.pl
Links to mgrast_dev_05262011: (view) (download) (as text) (annotate)
Tue May 31 14:05:18 2005 UTC (15 years, 1 month ago) by overbeek
fixes to computing coupling scores
Tue May 31 12:51:09 2005 UTC (15 years, 1 month ago) by overbeek
fixes to filtering PCHs
Sat May 7 20:57:47 2005 UTC (15 years, 1 month ago) by overbeek
Diff to selected 1.3
add routines for BigFC
