[Bio] / FigKernelScripts / compute_sim_chunk.pl Repository:
Log of /FigKernelScripts/compute_sim_chunk.pl
Wed Jan 25 18:58:09 2006 UTC (14 years, 1 month ago) by olson
Changes since 1.2: +3 -0 lines
add working-on-chunk support
Tue Jun 14 17:43:04 2005 UTC (14 years, 8 months ago) by olson
Start local sim compuation.
