[Bio] / FigKernelScripts / compute_ev_code_attributes.pl Repository:
Log of /FigKernelScripts/compute_ev_code_attributes.pl
Sat May 3 02:30:30 2008 UTC (12 years ago) by overbeek
do not include cluster-based subsystems in forming evidence codes
Mon Oct 15 19:13:49 2007 UTC (12 years, 7 months ago) by olson
CVS Tags: rast_rel_2008_04_23
pull subsystems, compute ev code attributes.
