[Bio] / FigKernelScripts / compute_ev_code_attributes.pl Repository:
Log of /FigKernelScripts/compute_ev_code_attributes.pl
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Sat May 3 02:30:30 2008 UTC (12 years, 2 months ago) by overbeek
do not include cluster-based subsystems in forming evidence codes
Mon Oct 15 19:13:49 2007 UTC (12 years, 9 months ago) by olson
CVS Tags: rast_rel_2008_04_23
pull subsystems, compute ev code attributes.
