[Bio] / FigKernelScripts / compute_contig_md5.pl Repository:
Log of /FigKernelScripts/compute_contig_md5.pl
Wed Apr 11 17:47:15 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.3: +90 -25 lines
rollup of metagenome server changes
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Mon Apr 25 15:36:33 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.1: +19 -13 lines
Tidy it up.
Mon Apr 25 15:29:41 2005 UTC (14 years, 6 months ago) by olson
Add compute_contig_md5 as a standalone tool to compute the checksum of a set of contigs.
Fix index_contigs.pl to produce the correct nucleotide counts in the signature file.
