[Bio] / FigKernelScripts / compare_figfam_release_results.pl Repository:
Log of /FigKernelScripts/compare_figfam_release_results.pl
Thu Oct 8 18:52:33 2009 UTC (10 years, 1 month ago) by arodri7
Changes since 1.4: +2 -1 lines
commit changes
Thu Apr 17 20:48:15 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Introduct &FIG::get_figfams_data()
Sun Apr 13 00:20:59 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.2: +5 -2 lines
fixes to FIGfam stuff
Fri Apr 11 14:15:15 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.1: +4 -5 lines
changes to FIGfams
Mon Mar 31 18:16:39 2008 UTC (11 years, 7 months ago) by arodri7
added the figfam quality control processes to the overall update process
