[Bio] / FigKernelScripts / collect_related_sequences.pl Repository:
Log of /FigKernelScripts/collect_related_sequences.pl
Fri May 11 18:51:28 2007 UTC (12 years, 6 months ago) by golsen
Changes since 1.2: +34 -66 lines
Encapsulate all of the SEED-dependent functions in the perl module.
It should still run all SEED-independent functions in any environment.
Sat Apr 28 22:35:02 2007 UTC (12 years, 6 months ago) by golsen
Changes since 1.1: +68 -9 lines
Improvements of functionality of finding related sequences in SEED.
Sat Apr 28 15:19:29 2007 UTC (12 years, 6 months ago) by golsen
Script to extract sequences from a fasta file with similarity to sequence
in a file.  This will be made more elaborate later.
