[Bio] / FigKernelScripts / close_connections.pl Repository:
Log of /FigKernelScripts/close_connections.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Mon Aug 27 18:27:33 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.1: +1 -29 lines
add strip comments argument on function_of
Sun Aug 26 14:58:12 2007 UTC (12 years, 10 months ago) by overbeek
Diff to selected 1.2
add new version of close_connection
