[Bio] / FigKernelScripts / check_subs_and_split_warnings.pl Repository:
View of /FigKernelScripts/check_subs_and_split_warnings.pl
Revision 1.3 - (download) (as text) (annotate)
Wed Feb 27 17:51:17 2008 UTC (11 years, 8 months ago) by overbeek
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
minor fix to handle deleted subsystems
use FIG;
my $fig = new FIG;
open(RUN,"$FIG_Config::bin/check_all_subsystems | sort |")
    || die "could not run check_all_subsystems";
my %seen;
my $line = <RUN>;
while ($line && ($line =~ /^([^\t]+)/))
    my $sub = $1;
    $seen{$sub} = 1;
    if (open(OUT,">$FIG_Config::data/Subsystems/$sub/warnings"))
	while ($line && ($line =~ /^([^\t]+)/) && ($1 eq $sub))
	    print OUT $line;
	    $line = <RUN>;
	close(OUT);
    else
            $line = <RUN>;
        warn "Could not open $FIG_Config::data/Subsystems/$sub/warnings\n";
foreach my $sub ($fig->all_subsystems)
    if ((! $seen{$sub}) && open(TMP,">$FIG_Config::data/Subsystems/$sub/warnings"))
	close(TMP);
