[Bio] / FigKernelScripts / check_starts_for_peg_sets.pl Repository:
Log of /FigKernelScripts/check_starts_for_peg_sets.pl
Wed Aug 31 21:20:33 2005 UTC (14 years, 7 months ago) by overbeek
Minor cosmetic changes
Thu Jul 28 17:45:37 2005 UTC (14 years, 8 months ago) by overbeek
modifications to correcting starts code
Sun Jul 24 15:54:40 2005 UTC (14 years, 8 months ago) by overbeek
fixes to start predictions
Sun May 15 11:49:37 2005 UTC (14 years, 10 months ago) by overbeek
minor fixes in computing functional coupling
