[Bio] / FigKernelScripts / check_sims_basic.pl Repository:
Log of /FigKernelScripts/check_sims_basic.pl
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Mon Sep 4 20:21:31 2006 UTC (13 years, 4 months ago) by redwards
using is_environmental instead of seven 9s
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Fri Jul 8 18:02:10 2005 UTC (14 years, 6 months ago) by overbeek
CVS Tags: caBIG-00-00-00, caBIG-dataload-0, merge-trunktag-bodev_news-3
Changes since 1.5: +52 -4 lines
minor fix to phylogernetic profiles
Mon Apr 18 20:08:15 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.4: +28 -35 lines
add process_sim_deletions_and_replacements
Fri Mar 11 20:52:34 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.3: +54 -52 lines
Fixed bugs and warts in mod to make work as either file or filter. -- /gdp
Tue Feb 8 21:32:27 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.2: +3 -0 lines
Added a comment. -- /gdp
Sat Feb 5 02:07:14 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.1: +97 -9 lines
Added "de-linting" option; made syntax somewhat more user-friendly. -- /gdp
Sun May 30 06:22:40 2004 UTC (15 years, 7 months ago) by overbeek
Diff to selected 1.2
add check_sims_basic
