[Bio] / FigKernelScripts / check_model.pl Repository:
Log of /FigKernelScripts/check_model.pl
Wed Nov 12 18:29:31 2008 UTC (11 years, 4 months ago) by dejongh
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
switch to scenario_directory
Tue Feb 5 02:27:15 2008 UTC (12 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.5: +141 -141 lines
Fixed a POD error.
Sat Sep 29 15:41:15 2007 UTC (12 years, 6 months ago) by mkubal
Changes since 1.4: +162 -0 lines
added cofactors to check
Fri Jul 27 18:53:31 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.3: +48 -54 lines
Updated searching algorithm. Added manual input ATP(C00002) which dramatically improves results - Kevin
Mon Jul 23 20:31:01 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.2: +1 -14 lines
Fixed calls to $fig->model_directory() - Kevin
Fri Jul 20 15:01:42 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.1: +26 -4 lines
Fixed filehandle errors for RAST server. Made compatable with seed standalones still too.
Script now uses $fig->model_directory() to retrieve file locations - Kevin
Tue Jul 17 16:15:00 2007 UTC (12 years, 8 months ago) by formsma
Initial revision of check_model.pl. This script is used to determine fesibility of predicted model reactions from given inputs, and also generates information about unreachable biomass compounds and scenarios - Kevin
