Log of /FigKernelScripts/check_model.pl
Parent Directory
Revision
1.7 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Nov 12 18:29:31 2008 UTC (11 years ago) by
dejongh
Branch:
MAIN
CVS Tags:
HEAD,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
myrast_rel40,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912
Changes since
1.6: +1 -1 lines
Diff to
previous 1.6
switch to scenario_directory
Revision
1.6 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Feb 5 02:27:15 2008 UTC (11 years, 10 months ago) by
parrello
Branch:
MAIN
CVS Tags:
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
rast_2008_0924,
rast_rel_2008_04_23,
rast_rel_2008_06_16,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_release_2008_09_29
Changes since
1.5: +141 -141 lines
Diff to
previous 1.5
Fixed a POD error.
Revision
1.4 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Jul 27 18:53:31 2007 UTC (12 years, 4 months ago) by
formsma
Branch:
MAIN
Changes since
1.3: +48 -54 lines
Diff to
previous 1.3
Updated searching algorithm. Added manual input ATP(C00002) which dramatically improves results - Kevin
Revision
1.2 -
view)
download)
as text)
annotate)
[select for diffs]
Fri Jul 20 15:01:42 2007 UTC (12 years, 4 months ago) by
formsma
Branch:
MAIN
Changes since
1.1: +26 -4 lines
Diff to
previous 1.1
Fixed filehandle errors for RAST server. Made compatable with seed standalones still too.
Script now uses $fig->model_directory() to retrieve file locations - Kevin
Revision
1.1 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Jul 17 16:15:00 2007 UTC (12 years, 4 months ago) by
formsma
Branch:
MAIN
Initial revision of check_model.pl. This script is used to determine fesibility of predicted model reactions from given inputs, and also generates information about unreachable biomass compounds and scenarios - Kevin
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
