[Bio] / FigKernelScripts / check_model.pl Repository:
Log of /FigKernelScripts/check_model.pl
Tue Feb 5 02:27:15 2008 UTC (12 years ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.5: +141 -141 lines
Fixed a POD error.
Sat Sep 29 15:41:15 2007 UTC (12 years, 4 months ago) by mkubal
Changes since 1.4: +162 -0 lines
added cofactors to check
Fri Jul 27 18:53:31 2007 UTC (12 years, 7 months ago) by formsma
Changes since 1.3: +48 -54 lines
Updated searching algorithm. Added manual input ATP(C00002) which dramatically improves results - Kevin
Mon Jul 23 20:31:01 2007 UTC (12 years, 7 months ago) by formsma
Changes since 1.2: +1 -14 lines
Fixed calls to $fig->model_directory() - Kevin
Fri Jul 20 15:01:42 2007 UTC (12 years, 7 months ago) by formsma
Changes since 1.1: +26 -4 lines
Fixed filehandle errors for RAST server. Made compatable with seed standalones still too.
Script now uses $fig->model_directory() to retrieve file locations - Kevin
Tue Jul 17 16:15:00 2007 UTC (12 years, 7 months ago) by formsma
Initial revision of check_model.pl. This script is used to determine fesibility of predicted model reactions from given inputs, and also generates information about unreachable biomass compounds and scenarios - Kevin
